Hello everyone,
I hope you are well.
I am having the following problem.
When I try to draw or copy/paste in the model view that object appears in a different location in the paper view.
Also when I try to add dimensions, they appear in a different place too.
Screenshots attached.
Your help is highly appreciated.
Thank you in advance.
Best
Vanesa
Solved by maxim_k. Go to Solution.
Hi Vanesa - @kevinHGNEU ,
Please verify that you have the same view direction and coordinate system in both - Model space and inside viewport in the Layout.
Use UCS command to set the same coordinate system in Model and in Viewport. Then use PLAN command to set default view direction in both Model and viewport.
