AutoCad For MAC
AutoCad For MAC
No aplicable
Ich benützte AutoCad 2015 for Mac und bei mir geht der Befehl 3D rotate nicht!! Wie kann ich das ändern???
0 Me gusta
Responder
649 Vistas
12 Respuestas
Respuestas (12)
maxim_k
Welcome to the Autodesk Forums!
If I understand your question correctly: you have difficulties with changing 3d viewpoint in the drawing area.
If you are using full version of AutoCAD (not AutoCAD LT), than you can use 3DORBIT command to rotate view in 3D:
- Expand Status Bar with this button:
- Than use 3DORBIT button:
You can also use ViewCube - it is on the top right of the drawing area, or Shift+Scroll Wheel on mouse.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
No, i want to rotate a cube in 3D and i can’t select an axis. But thank you for your quick reply
0 Me gusta
maxim_k
Which axis you cannot select? Could you illustrate somehow?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Marc
0 Me gusta
maxim_k
Hi Marc,
If you tried to attach image, the attempt was unsuccessful :cara_de_decepción:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Be awesome
Marc
0 Me gusta
No aplicable
0 Me gusta
maxim_k
How to select axis of rotation in 3DROTATE command:
after pocking the center of rotation, hover with crosshair above the axis of rotation you need and when it turns orange (yellow), pick it, than specify the angle of rotation with two mouse clicks.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
yes, that is exactly what doesn't work. I can't select the axis... i don't know what to do!
0 Me gusta
maxim_k
Are the axis gets highlights when you hover with mouse on them?
Are you able to Rotate objects in 3D if you select object and change default Gizmo to Rotate option on the Status Bar?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
i tried it, it didn't work :cara_de_decepción: maybe if i delete auto cad and download it again? is this possible with only 1 license?
0 Me gusta
maxim_k
I think you need to try to reset AutoCAD: from menu AutoCAD select Reset AutoCAD.
Than test it again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
