AutoCAD for MAC how to put an entire layer in front
liznewman
liznewman
The best way I have figured out is to isolate the layer, select all, and then draw order/move to front.
I used this twice in a row to put hatched window tags in front of the drawing and the numbers in front of the hatch.  It looks good on the screen, like it worked, but the pdf does not show the numbers.  Huh?
dmfrazier
Sometimes it's necessary to move everything else to the back in addition to bringing the text to the front.
Another thing you might consider is using MText with background mask.
maxim_k
Hi @liznewman ,
You can also try to use TEXTTOFRONT command to bring all text objects to front.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
liznewman
Thanks, maxim_k - that worked great!
