AutoCAD 2018 for Mac hotfix failed and erased nonstandard apple apps
betazero
Message 1 of 18
betazero
I installed or tried to install the Autocad 2018 (it failed) for Mac hot fix and it erased any extra Apps that are not standard Apple Apps in my Application folder along with Autocad 2018..... WTF seriously..... VMware Fusion, DWG Maker, Autocad 2018, iMovie, Numbers, Pages all gone!!! Why would it even do that??? Is there a disgruntled Autodesk employee?
[The subject line of this post has been edited for clarity by cheryl.buck from: Seriously WTF!!!]
Replies (17)
Message 2 of 18
betazero
And BetterSnapTool
Message 3 of 18
betazero
Oh yea and my whole Adobe suite of CC apps.....
Message 4 of 18
maxim_k
Which way it failed? Did you get any alerts? Can you describe in more details what happened?
I cannot believe AutoCAD installer erased all apps from Application folder on your Mac. Are you absolutely sure?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 18
maxim_k
And do you mean "AutoCAD for Mac®2018.1 Update"?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 18
betazero
1000%. Everything was working then I installed the hot fix and it basically sent my Mac back to startup apps....I don't use too many apps on my Mac. Literally the ones I mentioned above. The only thing I did was install the hot fix. I for sure had Autocad for Mac on my Mac because the installer had to close it. Also I got the update from inside Autocad.
It was installing and got to the last step and said the install failed ( probably because it deleted Autocad for Mac...).
Message 7 of 18
betazero
Yes 2018.1
Message 8 of 18
betazero
It took out my Dropbox too....
Message 9 of 18
maxim_k
I think it is not AutoCAD installer "work".
You need to try to use Disk Utility to check your Mac drive.
Do you have Time Machine backup (or other type of full system backup, for example CCC) of your system?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 18
john.vellek
Hi @betazero,
This is terrible. I just applied the new update and had no issues.  I don't think the installer touches any of these items so this very perplexing.
Do you have all of your system backed up (TimeMachine perhaps)?  This is likely to get you back up and running but I would like to get a better idea of what happened during the installation. Have you checked to see if some of this might have been "moved" to iCloud or marked as hidden?
Have you browsed to your application folder to manually check for the apps?
Here is a link that might help if they are just missing from your Launchpad
John Vellek
Message 11 of 18
wei503
@betazero, can you please find the install log and send to me in email: wei.ma@autodesk.com.
Open Console window(search console in splotlight to get it) > in the navigation bar on the left, select /var/log, right click it and select Reveal in Finder > in the Finder window, find the install.log file
Wei
Wei Ma
AutoCAD QA Manager
Message 12 of 18
betazero
I disagree. This is a brand new computer and It wiped out down to when my computer was just turned on right after installing and failing at the 2018.1 update. There is some kind of bug in the installer is what I think. Not sure how ore why there would be something that does this.
No I don't use any backup system like Time machine etc. My files are in Dropbox which handles that. I believe in keeping it simple and you have fewer problems.
Did the Disk Utility thing anyways( no problems found) If it was a disk problem it would not have picked only installed apps:
Verifying file system.
Volume could not be unmounted.
Using live mode.
Performing fsck_apfs -n -l -x /dev/rdisk1s1
Checking volume.
Checking the container superblock.
Checking the EFI jumpstart record.
Checking the space manager.
Checking the object map.
Checking the APFS volume superblock.
Checking the fsroot tree.
Checking the snapshot metadata tree.
Checking the extent ref tree.
Checking the snapshots.
Verifying allocated space.
The volume /dev/rdisk1s1 appears to be OK.
File system check exit code is 0.
Restoring the original state found as mounted.
Operation successful.
Message 13 of 18
betazero
Wow thats a long log file... Ok
Message 14 of 18
betazero
Looks like it could have been Worse. It was trying to rename all the stock apps too ???? WTF ???????
toCAD_Mac_2018.1_Update_Combo.pkg#autocad2018.pkg (destination=/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSandboxManager/62CE246C-FC49-477C-A627-E437C37A241A.activeSandbox/Root/tmp/_adsk_22.0.48.478/autocad2018.O048.M.478, uid=0)
2018-04-26 08:45:47-04 Russells-iMac installd[763]: PackageKit: Extracting file://localhost/Volumes/O048.M.478.acad.mac.x64.comboupdate/AutoCAD_Mac_2018.1_Update_Combo.pkg#AdSSO-v2.pkg (destination=/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSandboxManager/62CE246C-FC49-477C-A627-E437C37A241A.activeSandbox/Root/Library/Application Support/Autodesk/AdSSO, uid=0)
2018-04-26 08:45:47-04 Russells-iMac installd[763]: PackageKit: Moving directory /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSandboxManager/62CE246C-FC49-477C-A627-E437C37A241A.activeSandbox/Root/tmp to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSandboxManager/62CE246C-FC49-477C-A627-E437C37A241A.activeSandbox/Root/private/tmp in sandbox to account for symlink
2018-04-26 08:45:47-04 Russells-iMac installd[763]: PackageKit: prevent user idle system sleep
2018-04-26 08:45:47-04 Russells-iMac installd[763]: PackageKit: suspending backupd
2018-04-26 08:45:47-04 Russells-iMac installd[763]: PackageKit: Executing script "./preinstall" in /private/tmp/PKInstallSandbox.N8xWeb/Scripts/com.autodesk.AdSSO-v2.ji0aLv
2018-04-26 08:45:47-04 Russells-iMac installd[763]: ./preinstall: AdSSOPackageInstaller: preinstall /Volumes/O048.M.478.acad.mac.x64.comboupdate/AutoCAD_Mac_2018.1_Update_Combo.pkg /Library/Application Support/Autodesk/AdSSO / /
2018-04-26 08:45:47-04 Russells-iMac install_monitor[777]: Temporarily excluding: /Applications, /Library, /System, /bin, /private, /sbin, /usr
2018-04-26 08:45:47-04 Russells-iMac install_monitor[777]: PackageKit: Locking applications
2018-04-26 08:45:47-04 Russells-iMac installd[763]: ./preinstall: AdSSOPackageInstaller: Install path is '/Library/Application Support/Autodesk/AdSSO'
2018-04-26 08:45:47-04 Russells-iMac installd[763]: PackageKit: Using trashcan path /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/PKInstallSandboxTrash/62CE246C-FC49-477C-A627-E437C37A241A.sandboxTrash for sandbox /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSandboxManager/62CE246C-FC49-477C-A627-E437C37A241A.activeSandbox
2018-04-26 08:45:47-04 Russells-iMac installd[763]: PackageKit: Shoving /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/PKInstallSandboxManager/62CE246C-FC49-477C-A627-E437C37A241A.activeSandbox/Root (2 items) to /
2018-04-26 08:45:47-04 Russells-iMac installd[763]: PackageKit: Executing script "./postinstall" in /private/tmp/PKInstallSandbox.N8xWeb/Scripts/com.autodesk.autocad2018.O048.M.478.update.NGkKfn
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: starting ......
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: The files is in /tmp/_adsk_22.0.48.478/autocad2018.O048.M.478
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: moving the old data to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/App Store.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/App Store.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Automator.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Automator.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Calculator.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Calculator.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Calendar.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Calendar.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Chess.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Chess.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Contacts.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Contacts.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/DVD Player.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/DVD Player.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Dashboard.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Dashboard.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Dictionary.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Dictionary.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/FaceTime.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/FaceTime.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Font Book.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Font Book.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Image Capture.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Image Capture.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Launchpad.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Launchpad.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Mail.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Mail.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Maps.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Maps.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Messages.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Messages.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Mission Control.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Mission Control.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Notes.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Notes.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Photo Booth.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Photo Booth.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Photos.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Photos.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Preview.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Preview.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/QuickTime Player.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/QuickTime Player.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Reminders.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Reminders.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Safari.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Safari.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Siri.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Siri.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Stickies.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Stickies.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/System Preferences.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/System Preferences.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/TextEdit.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/TextEdit.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Time Machine.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Time Machine.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/Utilities to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/Utilities: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/iBooks.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/iBooks.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: mv: rename /Applications/iTunes.app to /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tempolddata.GS1t74QQ/iTunes.app: Operation not permitted
2018-04-26 08:45:48-04 Russells-iMac installd[763]: ./postinstall: Can't move the old data!
2018-04-26 08:46:31-04 Russells-iMac install_monitor[777]: Re-included: /Applications, /Library, /System, /bin, /private, /sbin, /usr
2018-04-26 08:46:31-04 Russells-iMac install_monitor[777]: PackageKit: Unlocking applications
2018-04-26 08:46:31-04 Russells-iMac install_monitor[777]: PackageKit: Error unlocking app: The file “AutoCAD 2018.app” doesn’t exist.
2018-04-26 08:46:32-04 Russells-iMac installd[763]: PackageKit: releasing backupd
2018-04-26 08:46:32-04 Russells-iMac installd[763]: PackageKit: allow user idle system sleep
2018-04-26 08:46:32-04 Russells-iMac installd[763]: PackageKit: Install Failed: Error Domain=PKInstallErrorDomain Code=112 "An error occurred while running scripts from the package “AutoCAD_Mac_2018.1_Update_Combo.pkg”." UserInfo={NSFilePath=./postinstall, NSURL=file://localhost/Volumes/O048.M.478.acad.mac.x64.comboupdate/AutoCAD_Mac_2018.1_Update_Combo.pkg#autocad2018.pkg, PKInstallPackageIdentifier=com.autodesk.autocad2018.O048.M.478.update, NSLocalizedDescription=An error occurred while running scripts from the package “AutoCAD_Mac_2018.1_Update_Combo.pkg”.} {
NSFilePath = "./postinstall";
NSLocalizedDescription = "An error occurred while running scripts from the package \U201cAutoCAD_Mac_2018.1_Update_Combo.pkg\U201d.";
NSURL = "file://localhost/Volumes/O048.M.478.acad.mac.x64.comboupdate/AutoCAD_Mac_2018.1_Update_Combo.pkg#autocad2018.pkg";
PKInstallPackageIdentifier = "com.autodesk.autocad2018.O048.M.478.update";
2018-04-26 08:46:32-04 Russells-iMac installd[763]: PackageKit: Running idle tasks
2018-04-26 08:46:32-04 Russells-iMac Installer[748]: install:didFailWithError:Error Domain=PKInstallErrorDomain Code=112 "An error occurred while running scripts from the package “AutoCAD_Mac_2018.1_Update_Combo.pkg”." UserInfo={NSFilePath=./postinstall, NSURL=file://localhost/Volumes/O048.M.478.acad.mac.x64.comboupdate/AutoCAD_Mac_2018.1_Update_Combo.pkg#autocad2018.pkg, PKInstallPackageIdentifier=com.autodesk.autocad2018.O048.M.478.update, NSLocalizedDescription=An error occurred while running scripts from the package “AutoCAD_Mac_2018.1_Update_Combo.pkg”.}
2018-04-26 08:46:32-04 Russells-iMac installd[763]: PackageKit: Removing client PKInstallDaemonClient pid=748, uid=501 (/System/Library/CoreServices/Installer.app/Contents/MacOS/Installer)
2018-04-26 08:46:32-04 Russells-iMac installd[763]: PackageKit: Done with sandbox removals
2018-04-26 08:46:32-04 Russells-iMac Installer[748]: Install failed: The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
2018-04-26 08:46:32-04 Russells-iMac Installer[748]: IFDInstallController 106E0 state = 8
2018-04-26 08:46:32-04 Russells-iMac Installer[748]: Displaying 'Install Failed' UI.
Message 15 of 18
wei503
Thanks for the log. We will need to investigate this issue to find what caused this issue.
I also need to validate the install file you have.  Could you please share the install file on your disk with me, with any network drive. Please send the link to my email at: wei.ma@autodesk.com
Wei
Wei Ma
AutoCAD QA Manager
Message 16 of 18
betazero
Sorry I no longer have it. It did a great job of deleting itself and Autocad too. I am not going to be reinstalling Autocad because I lost like an half hour reinstalling apps. It wasn't the end of the world but it sure was a surprise.
I can tell you for sure I downloaded it today and the prompt to download it popped up in Autocad.
Message 17 of 18
wei503
Hi @betazero
We have found the issue in the install script, and are working on fix.
I just want to check with you that, did you put the AutoCAD 2018.app directly in the /Applications/ folder? Normally, it should be installed in /Applications/Autodesk/AutoCAD 2018/ folder.
Wei
Wei Ma
AutoCAD QA Manager
Message 18 of 18
wei503
Update:
The issue has been fixed. The 2018.1 installer is already updated.
The issue happens in a rare scenario, and the impact is in the installation process. The issue does not impact the files or functionality of AutoCAD if the installation is successful. There is no difference of the AutoCAD 2018.1 upgraded from the original installer or the new installer.
Wei Ma
AutoCAD QA Manager
