AutoCad 2016LT Ribbon does not appear
I have looked on youtube, forums, etc. I must have something set up wrong because when I type in ribbon in the command line I don't get a pull down option to select palette. Also I do not have the gear icon to select. I have two ribbons that show up one on the side and one on the bottom. They do not show all of the icons that I see on other posts or youtube videos
Gerry
rkmcswain
You'll have better luck asking in the AutoCAD for MAC forum.
pendean
Community Legend
Community Legend
There is no Windows-based PC Ribbon on the MAC version, if that's what you mean.
Otherwise if you are running Windows on that MAC and Windows-version of LT then select a new workspace with WORKSPACE command (you can type it) or reset it as explained here https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
john.vellek
Hi @Anonymous,
This is what my AutoCAD LT 2016 for Mac looks like.
If you use the Window drop-down menu you can show more or less palettes as you desire.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Hi doug,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
