AutoCAD 2015 LT for MAC pinwheels
Message 1 of 14
AutoCAD 2015 LT for MAC pinwheels everytime I copy/insert/paste or any other additive function. I'm using a MBP 15" mid 2015 running 10.11.6. AutoCAD is up to date and this problem started happening about a week ago. The only thing different is that I added a Mini-display port to Dual DVI adapter for a Dell 3007WFPHC
Replies (13)
Message 2 of 14
Emmsleys
Does it happen even if you log in as a different user on your system?
Sarah Emmsley
Technical Support Specialist
Message 3 of 14
maxim_k
Do you have troubles if you don't use external display?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 14
Yes, it occurs when the Laptop is only using it attached monitor
Message 5 of 14
It does not seem to,  Setup a new user and did some simple test and it work smoothly...  What gives??
Message 6 of 14
maxim_k
>>>> Dual DVI adapter
Is it this one:
http://www.apple.com/shop/product/MB571LL/A/mini-displayport-to-dual-link-dvi-adapter?fnode=8b&fs=f%...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 14
Yes, that is the one..
Message 8 of 14
Emmsleys - i think you might have a solution...  Can you expand on Autocad LT for Mac working under another different user Logon?
Thank you
Roaming Engineer
Message 9 of 14
Emmsleys
Of course, happy to help!
I've suggested logging in as a separate user as a troubleshooting step before resetting your settings to default. This way you are able to test AutoCAD in a default settings and a new user profile.
Unlike the Windows version of AutoCAD you can not save your custom settings in AutoCAD for the Mac.
I would recommend creating a new user login and testing AutoCAD with now custom profiles or settings. Let me know if that helps.
Sarah Emmsley
Message 10 of 14
Emmsleys - it did work, by logging on as a test user on my mac, AutoCAD 2015 worked without pin wheeling.  So how do I set my settings back to default on my orginal log-on
Thank you for you help
Message 11 of 14
Emmsleys
Hey @Anonymous,
Look to the steps below from this AKN article
AutoCAD for Mac 2014 SP1 and later:
To reset the palettes:
  • Click the Window menu and choose Reset Palettes or enter RESETPALETTES on the command line.
To reset the entire program:
  • Hold down the Shift key while starting AutoCAD for Mac.
  • In AutoCAD for Mac 2015 and newer, you may click the AutoCAD (or AutoCAD LT) menu and choose the option to reset the program.
User-added image
  • For all versions of AutoCAD for Mac, do the following:
  1. Click Preferences under the AutoCAD menu.
  2. Click the Application tab.
  3. Click the button "Reset Application Options."
  4. Click "Reset AutoCAD."
User-added image
Sarah Emmsley
Message 12 of 14
Emmsleys
Let me know if that doesn't work.
Sarah Emmsley
Message 13 of 14
Emmsleys - Thank you so very much...   ALL Good
Message 14 of 14
Emmsleys
@Anonymous,
You are welcome. Have a great weekend.
Sarah Emmsley
