Autocad 2015 Crash on StartUp with Mac OS X
Message 1 of 16
Hi.
Im new here...im just installed autocad 2015 student version. crash during startup (mac os sierra )... autocad cant run.. its just not responding... help please.. thanks
Replies (15)
Message 2 of 16
maxim_k
Welcome to Autodesk Forums!
Hi @Anonymous,
In order to be able to use 2015 version of AutoCAD on macOS Sierra, you need to install an Update to AutoCAD 2015 form here:
https://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-2015...
At the same time, as you have student subscription, you are eligible to use the latest version of AutoCAD - 2017, which is fully compatible with Sierra. If you don't see download link to 2017 version in your account management page, you can download it using Autodesk Virtual Agent:
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
https://knowledge.autodesk.com/community/screencast/9e086aca-5439-4336-9a1d-e33ff069d60b
You just need to use the link to Mac version:
Now you can install 2017 version and activate it with your student serial number. The product key for 2017 version is 777I1
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 16
is't mean i have uninstall the 2015 version first
Message 4 of 16
maxim_k
It doesn't rally matter. You can uninstall it or leave - it is up to you.
But if it don't launch, you can uninstall it with "Remove AutoCAD.app"
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 16
Autodesk just give me an option to install 2 times only for the activation code ... thus it mean im already once for it
Message 6 of 16
*already used it once
Message 7 of 16
maxim_k
Not 2 times, but on two different machines.
As you install AutoCAD on one machine, different releases, but with the same serial, this counts as 1 machine.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 16
Im sorry maxim,
I've already download and install 2017 version... but 2017 much more worse.. after installing it just crash ... for your info im install it in imac mid 2011  on mac os Sierra.. is it my hardware or the os
Message 9 of 16
wei503
Could you please send out the crash report, and let me know the report ID. The ID is shown in the popup browser page after you send out the report, and it is in format: CER_xxxxxxxx.
Wei
Wei Ma
AutoCAD QA Manager
Message 10 of 16
maxim_k
What do you mean by "crash"?
Does it shows window similar to this:large.jpg
Have you passed activation window, where you asked to enter serial number and product key?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 16
After installed finish the opening just loading and the program not
responding.. In 2015 autocad before installed the autocad ask me to key in
the Sn and Pkeys... sorry for the late reply..
Message 12 of 16
the autocad 2017 just keep loading.. and i have to quit not force quit... so theres no report... i have reinstall several time still dont work
Message 13 of 16
I downloaded auto cad 2015 on my mac (10.11), and it was working fine until recently. Whenever I run the program, or open a file, it would crash immediately after opening. and i get the same dialogue box you displayed.
would appreciate your help.
thanks
may
Message 14 of 16
maxim_k
Hi May,
Have you installed latest update to AutoCAD 2015?
Here is the link to Update:
If you already installed Update 4, I'd recommend you to perform clean uninstall:
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/sfdcarticles/sfdcarticles/...
Then install 2015 version again (if you want to stick with it) and install the Update I mentioned above.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 16
please provide product key & serial no. for 2015
Message 16 of 16
maxim_k
Hi @Anonymous,
You can find product key and serial number for AutoCAD 2015 on your Autodesk account page:
https://manage.autodesk.com/cep
Of course, if you purchased 2015 version.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
