AutoCAD 2014 previously worked, now doesn't
AutoCAD worked fine for a couple years. Now, it won't open. The splash page pops up for a fraction of a second and then goes away and the program never starts.
I tried deleting all AutoCAD data in Library/Autodesk, Library/Application Support/Autodesk, and Applications/Autodesk and then resinstalling and it still is not working. It's not a system requirement issue because it has worked in the past. I'm not sure what to do 😞
Yosemite 10.10.5
Processor: 2.5 GHz Intel Core i7
Memory: 16 GB 1600 MHz DDR3
maxim_k
Welcome to Autodesk Forums!
Try Clean uninstall:
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
Than install again.
Don't forget to apply all updates after the installation/
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Have you applied all updates to AutoCAD 2014?
Has anything recently changed on your system?
Sarah Emmsley
Technical Support Specialist
