Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Autocad 2011 for Mac - Missing commands
Message 1 of 28
Several commands do not work in the AutoCAD 2011 for mac version. The shortcuts are on the CUI interface, but when you try these shortcuts or type the command, they don't work (message: unknown command).
Example (among others):
_qselect  (Quick select)
_drawingrecovery (drawing recovery manager)
Thanks in advance for your help solving this.
Replies (27)
Message 2 of 28
try posting in the (fairly new) MAC threads....
Message 3 of 28
Johneng
AutoCAD features that are not yet available in AutoCAD for Mac can be found at the following link. Drawing recovery manager is about 14th on the list
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15833488&linkID=15839490
Message 4 of 28
Thanks very much for your response.
It is quite unfortunate that these commands are not available yet and that we did no know about it (some of them are important tools). I hope they will be available soon and specially that we will be able to incorporate them in our version somehow.
Thanks again.
Message 5 of 28
I can't seem to find the multiline style window in AutoCAD for Mac 2011. I couldn't see that they were omitted in the list of features not included in the Mac version. Does someone know where they are?
Message 6 of 28
stAte option in the -LAYER  I tried looking for this in the menu or command, but I was unsuccessful.
Please help me find this command. Thanks
Message 7 of 28
OK, figured it out. The command isn't built into the software. I had to install Windows on my Mac and then download and install the Windows version of this software. I think not having these commands is a big miss, and I question the wisdom of releasing the product without them.
Message 8 of 28
maxim_k
Hi xaffier,
Layer State option is here:
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 28
Thanks for the tip. I have found it but it didn't help about Layer Manager issues.
Hopefully it will be integrated in the 2012 version in March
cheers
Message 10 of 28
maxim_k
cheers
Not sure, what kind of  Layer Manager issues did you mean?
About integrating Layer states manager into Layers Palette?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 28
Layer Manager, i use it to control the display of various sets of layers status. Like, floor finish plan, ceiling plan, architectural plan, furniture plan... In windows' version there is a dialogue box that appears and let you save the layers in sets. I hope i explain it right. Maybe someone, maybe you, happen to know such feature in mac version. Cheers, X
Message 12 of 28
maxim_k
Hi xaffier,
OK, I got it.
Unfortunately сurrently there is no such a functionality in the AutoCAD for MAC, only command line version.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 28
Hi, does anybody know what command to use in order to perform equivalent to ctrl+tab in widows (shifting through different opened cad files)?
thanks
Message 14 of 28
maxim_k
Hi, You can use "Command+~"
More about Shortcut Keys in AutoCAD for Mac see in my blog
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 28
thanks maxim,
but i hate having to use both hands. can i change it? where?
thanks again!
Message 16 of 28
maxim_k
I think it is system related, so you can't change it (like Ctrl+Tab on Windows).
why two hands?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 28
John
Can we map the Function keys as they were in the PC version (i.e. F3 toggle snap, F7 toggle grid, F8 toggle ortho)?
Alan
Message 18 of 28
I am having trouble while trying to modify the dim settings,everytime I go into dim/modify and try to change arrows,txt,ofsets e.t.c when I go to save settings autocad hangs.can anyone help?
Message 19 of 28
maxim_k
Welcome to Autodesk Forums!
Which OS do you have on your Mac, if it is 10.9 (Mavericks), than AC 2011 is not compatible with this OS and Dim Style dialog will not work properly in it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 20 of 28
well you hit the nail on the head,I'm running-2007 mac bk pro 2.5GHz intel
core 2 duo/4gb 667MHz DDR2 SDRAM/ NVIDIA GeForce 8600M GT 512 MB
