Attribute Extraction Issues
liamrobertsSP
Message 1 of 9
liamrobertsSP
I am trying to extract information on blocks from a drawing to create an order sheet. Attached is the template I have put together and also a screenshot of the block reference I am trying to take the attributes from.
Once I select the template file to export using there is no option to generate the text file. I just get no further action.
Replies (8)
Message 2 of 9
maxim_k
Hi @liamrobertsSP ,
I think that the fields which represent block information - BL:NAME BL:LAYER and BL:NUMBER in your case - should be at the beginning of the template file. Attribute fields should follow BL: fields.
For example:
BL:NAME C020000
BL:LAYER C100000
BL:NUMBER C100000
PL202J C010000
S-Code C100000
UNIT_TYPE C010000
POWER C010000
Try to correct the template.
BTW - what do you see in the Command window after you select the Template file?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
liamrobertsSP
Thank you, I changed the template and it hasn't worked, unfortunately. I have attached a template I use for coordinate extraction which works as expected when I run it.
I get nothing back at all from the programme once I select the template file (the first one I posted).
The second template attached is the first with the added information I want in this new case.
Message 4 of 9
liamrobertsSP
Hello @maxim_k .
Message 5 of 9
maxim_k
Can you share your block?
I will try to figure out what happens.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 9
liamrobertsSP
Of course, attached below.
Sorry for the delay.
Message 7 of 9
maxim_k
@liamrobertsSP ,
You attached your drawing in wrong place.
See my answer >>>>HERE<<<<
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 9
liamrobertsSP
Sorry @maxim_k that was a different block I am having some other issues on the stretching of (I can't get the attributes tos tay in the middle).
The correct block for data extraction is here.
Message 9 of 9
maxim_k
Hi @liamrobertsSP ,
There is a mistake in your template, in "Block counter".
In your template it is: BL:NUMBER C100000 (C- character data), but should be: BL:NUMBER N100000 (N - numeric data).
That is why I asked what do you see in the command window.
If I use your template, AutoCAD reports in the Command window:
** Invalid field specification:
BL:NUMBER C100000
If you change "BL:NUMBER C100000" to "BL:NUMBER N100000" - everything works fine.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
