ARM architecture compatible AutoCAD
ohelcl
Message 1 of 34
ohelcl
Dear,
simple question. When can we expect M1 compatible version of AutoCAD? Running AC with Rosetta 2 is kind of laggy and low fps. Currently deciding if I should keep the Macbook or return it, because I use AC all day everyday.
Thanks in advance.
Ondra
Replies (33)
Message 21 of 34
wei503
We have the MBA almost same as yours. I don't see AutoCAD behaves differently from on Intel based Mac. I don't know how bad it shows on you machine. I can see a little slow when moving cursor in canvas than on other UI. It could be improved in future, but it is just how AutoCAD currently works on Mac, and it is not specific on M1 Mac.
Wei Ma
AutoCAD QA Manager
Message 22 of 34
maxim_k
Hi @ohelcl
Can you create screencast to show the problem you have here?
If yes, please show us the performance in 2D and in 3D.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 23 of 34
ohelcl
Okey, and could you compare it with window version? Is there a notable difference? You can be right and it is normal for Mac OS, but I have never experienced Mac AutoCAD and coming from windows it is big difference for me.
Message 24 of 34
ohelcl
Here it is, but as it is shot with low fps the problem is not really visible, but it gives you better idea when the problem occurs. When I am moving the view in 2D field it is low fps, when I start to move the view in 3 dimensions it smoothens up.
Message 25 of 34
maxim_k
In my case, if I test my standard drawings, I don't see any difference in graphics performance in AutoCAD on Mac (both Intel and M1) and on PC.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 26 of 34
maxim_k
>>>>Here it is.
Sorry, but I don't see attachment with screencast...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 27 of 34
ohelcl
video
Message 28 of 34
maxim_k
>>>video
No video at all.
You need to reply in browser in order to be able to attach something to your post.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 29 of 34
ohelcl
Sorry, it is removing it because of "Your post has been changed because invalid HTML was found in the message body.". Working on it.
Message 31 of 34
maxim_k
Sorry, but this screencast does not give a good idea of the difference between 2D and 3D performance. In my opinion, it is the same in both cases.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 32 of 34
ohelcl
yes, unfortunately it is not visible
Message 33 of 34
maxim_k
Another one attempt.
Can you check System Variable DTTEXT ?
If DTTEXT=1 in your case, try to set it to 0 (zero).
Do you see any difference in performance with DTTEXT=0 ?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 34 of 34
ohelcl
No difference at all, thanks for trying.
