Annotative blocks on an XRefed file only shows when Annotation scale is set to underscored scale
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all, I'm using AutoCAD LT for Mac and there's some issue with Xref/Annotation scaling.
I drew some annotative objects(blocks/texts/dimensions/etc) with annotative scaling property of 1:100, 1:150 on file 'A'.
Then I XRefed 'A' into 'B'.
I also drew some annotative objects with 1:100, 1:150 on file B.
In file B, when I set the file's drawing scale to '1:100', it only shows objects drawn on B and the objects in A disappears.
There's a scale named '1:100_XREF' and when I set that as the drawing scale it only shows objects in A and not in B.
When I set the scale to '1:150', it shows all the objects with '1:150' property, both on A, and B, which is what I want with 1:100.
Shouldn't the objects in A also show when I just set the scale to '1:100'?
pls help.
Also, ANNOALLVISIBLE is not the solution I want.
I can't delete scales with '_XREF' in the name.
scales with '_XREF' in the name imports into B even when there is already same scale existing in the scale list.
