AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Annotative Blocks Coming in as Non-annotative
3 REPLIES 3
bret_wieseler
645 Views, 3 Replies
I'm using Autocad 2018.1 update Alpha.  When I drag and drop annotative blocks from the content panel, some of them come in at the proper annotative scale, but several come in at a 1:1 scale and are shown to be non-annotative in the properties palette.  These blocks all reside in a common drawing file, and are all annotative.
The "Automatically add scale to automated objects" is checked
I've never had this issue in any other versions of the software before.
Any thoughts?
As an addendum to the original post, I noticed this issue does not occur when I drop these blocks into a default Autocad drawing template.  It only occurs in a drawing file that I have set up myself.
Curiouser and curiouser...
iMac | 3.6 GHz 8-Core Intel Core i9 | 64 GB | Ventura 13.6.6 | Autocad LT for Mac - 2024.1.2
3 REPLIES 3
maxim_k
in reply to: bret_wieseler
Hi Bret,
You should post questions about Alpha (Beta) software on Beta Forums, not here.
Most likely nobody can answer your question here, because the Forum is about shipping (final) version of AutoCAD for Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
bret_wieseler
in reply to: maxim_k
My mistake.  I will do that.  Thanks.
maxim_k
Anyway, please check that you don't have blocks (non-annotative) in your current drawing with the same name as annotative blocks you are trying to insert from Content Palette.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
