Adding items to floor plan
I can't figure out how to add figures, such as couches, beds, sinks, etc. to my floor plan. If I am doing something I would like some help.
maxim_k
Welcome to Autodesk Forums!
Hi Parker,
What AutoCAD version are you using?
If it is 2020, then you can use Blocks palette (Block libraries tab) to insert blocks ("figures") to your drawings.
https://help.autodesk.com/view/ACDMAC/2020/ENU/?guid=GUID-09389064-395E-4D18-99CF-7F6C18718EF3
But at first, you need to create your own block libraries with floor plan symbols.
You can find a lot of free blocks over the Internet, for example here:
https://www.cadforum.cz/catalog_en/
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Tiana_Y
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the information that @maxim_k  provided help you with this?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
