Add a new layout in an existing sheet to a project
Message 1 of 30
I have an existing project set up, which as numerous DWGs linked each with 1 or more layouts.  I now want to link a new layout in a DWG file thats already part of the project?
How do I do this without deleting the dwg from the project & then re-importing it again (losing all of the layout referencing in the process?
Replies (29)
Message 21 of 30
maxim_k
It is not release 4 it is only Update 4, which fixes existing major (sometimes minor) bugs.
But you are talking about additional feature, which can be added only in new application release and if this feature will be requested by many users.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 22 of 30
I disagree. What is the point in having the Project Manager if you can't load new layouts in an existing DWG into it? Over time, you could input quite a lot of info into the layout properties.
Having transferred over to AutoCAD from ArchiCAD, I've set up all of our templates to operate in this manner & that's what it's supposed to do (as per the Windows version).
Call it a release, update, or whatever you like; the issue needs fixing. Especially when they keep taking money out of my account each month for licenses.
Message 23 of 30
maxim_k
If you need this feature, you can submit your request here:
http://www.autodesk.com/company/contact-us/product-feedback
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 24 of 30
mauldindesigns
Community Visitor
Community Visitor
So this is still a problem... I have had the same issue for years, but usually in too much of a hurry to hassle with answers from the internet and most of my projects it does note effect, but I have a few that I am working on now that I really need this feature or I will be spending hours reloading plans.  Please tell me there has been a resolution to the Mac Project Manager and adding new sheets.
Thanks!
Message 25 of 30
richwilden
Observer
Observer
I have the same issue and I'm using AutoCAD LT 2022 for Mac. Are there any updates or workarounds I can use to get the functionality I need? I have over 60 layouts that I am using Project Manager layout information to populate hundreds of fields, so recreating the while set-up to add a couple layouts is a huge effort.
Message 26 of 30
maxim_k
Hi @richwilden ,
No updates and workarounds....
You can leave your feedback here:
https://www.autodesk.com/company/contact-us/product-feedback
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 27 of 30
luisQS2PB
This is absolutely appalling and disrespectful from Autodesk.
It's been 6 years since it was first reported and still nothing has been done.
Message 28 of 30
simao.mariz
Community Visitor
Community Visitor
AutoDesk, can you reply something?
How can this easy informative bug still be unfixed? It makes me want to migrate to windows just because of that
Message 29 of 30
griffinLGJJ2
2025 and still no project manager improvement on AutoCAD for mac.....
If you set up your sheet set and along the way create a new layout in a drawing already added to the sheetset, the only way to add that layout as a sheet is to manually delete each sheet from that dwg in the sheet set manager, and then add the whole drawing back to the sheetset.
i say manually because there is no view in the project manager that shows all the current drawings in the sheetset, nor are you able to multi-select sheets and delete at once. unacceptable!
Message 30 of 30
pendean
Community Legend
Community Legend
...unacceptable!
If you want Autodesk to "fix it", you and a few 100/1000 other subscribers have to ask for it in the same level of detail and clarity constantly over and over again over here at a different site, here is the link:
But first confirm it is a known issue with no fix - open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
