AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
ACAD MAC 2015 FONT INSTALLATION TROUBLES
21 REPLIES 21
Message 1 of 22
1614 Views, 21 Replies
I have tried installing a .ttf file to my mac, and then made sure it was in the correct folder for AutoCad to access, but it still won't show up! No matter how many different ways I've tried installing, editing, saving, etc - it still won't show up as an option in AutoCad. I'm trying to install Calibri Light.ttf. I've installed to computer then saved to the ttf file in AutoCad 2015-contents- roaming-etc. I've also restarted computer and AutoCad, nothing. I've tried changing the saved font path - nothing.
21 REPLIES 21
Message 2 of 22
maxim_k
In order to be able to use TTF font in AutoCAD for Mac you need to install it in your system with Font Book application, then it should be available in all applications on your Mac including AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 22
in reply to: maxim_k
I already did this and it shows up in my font book but not in autocad
Sent from my iPad
Message 4 of 22
maxim_k
Have you restarted AutoCAD?
Use QUIT command and launch it again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 22
maxim_k
Finally I figured out your problem. It is similar to this one:
http://forums.autodesk.com/t5/autocad-for-mac-general/font-weight-variants-autocad-2014/m-p/4873576/...
I attached here Calibri light font, which should work for you.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 22
Hi everybody - I'have probably similar problems with ttf font DIN Next Rounded Pro Light. There's this small yellow triangle...I've already tried everything, restarting Mac, Autocad...nothing worked. Is there any chance you could give me an advise?
I would really appreciate that.
Thanks, Tereza
Message 7 of 22
maxim_k
Welcome to Autodesk Forums!
Do you have this font correctly installed on your Mac?
Can you use it in applications other than AutoCAD?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 22
Hi, yes I can use it in all my Adobe programs and it's even installed in the FontBook. You know what is strange? That Regular and Bold version of DIN works normally.
Message 9 of 22
maxim_k
I think that this is the same issue as described (and solved) here:
http://forums.autodesk.com/t5/autocad-for-mac-forum/font-weight-variants-autocad-2014/m-p/4873576/hi...
You need to "split" DIN Next Rounded Pro font, than AutoCAD will see it and you will be able to use this font.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 22
How can I change de name of the font. Because when I install the file you've sent here, the name which appears in AutoCAD is "Calibri L", but I need that name "Calibri Light", otherwise the files don't recognize the other files that came from other computers with this font.
Thank you for everything,
Ana Claudia
Message 11 of 22
maxim_k
Hi @Anonymous ,
Try attached file.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 22
Thank you so much 🙂
Message 13 of 22
Do you know why the plot changes the font..?? It seems to not recognize when I plot. Do you know how to fix it?
Thank you very much
Captura de Tela 2021-06-08 às 16.02.03.pngCaptura de Tela 2021-06-08 às 16.02.18.png
Message 14 of 22
maxim_k
Hi @Anonymous ,
Please specify your AutoCAD version and macOS version installed on your Mac.
What font are you using in the drawing?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 22
The Calibri Light you've have sent me before.. Im using AutoCad 2021
Message 16 of 22
Message 17 of 22
maxim_k
Just tried and cannot reproduce your issue on my side. This font prints correctly to PDF.
What printer are you using?
Do you have this issue wit all drawings with this font?
Can you share your drawing here?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 18 of 22
I use to use the plot "dwg to pdf". All the drawings I've tried, I've got the same problem.
I'll send you one of the drawings..
Message 19 of 22
maxim_k
Take a look at the attached PDF.
Does it look correctly? Don't mind the color - I don't have your plot style table CTB file.
I "printed" it on my Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 20 of 22
Yes, that's perfect! How can I fix mine?
