Wire Color/ID for 2nd Cable Marker
I have to add 2nd cable marker for my drawings, especially if one of the cable end is in the other page. To assign all cable conductors to a cable, it can be defined in the conductor list for the cables in the catalog. When the cable chosen from the catalog it assigns the wire color/ID automatically. But it only works for the 1st cable marker. When the 2nd cable marker is added it shows a message "no more cable conductors available". It would be nice if it show/assign the wire color/ID to the marker automatically after putting 2nd marker. It is possible to choose/define wire color for the 2nd cable markers BUT it is needed to select all core's symbol and type or select from Generic Colors one by one. It is very time consuming for the cables have much cores.
(view in My Videos)
1 Comment
rhesusminus
Autodesk fantastic idea, is that you should be using the "Extra marker" on the other side of the connection:
This will however, NOT be updated if you change the cable/conductors 😄 😄 😄 😄
