Terminal Strip Export/Wago
It is possible to export the Terminal Strip to Wago. The exported .xml file is compatible with Wago ProServe 6.0. The thing is that Wago ProServe does not exist anymore, and Wago has another tool for digital engineering, which is called WAGO Configurator Smart Designer. Seems the .xml export from ACADE is not compatible with the WAGO Configurator Smart Designer so it is possible to export but impossible to import the .xml to the WAGO designer. It is crucial to use WAGO designer to industrialize the terminal strip to check the compatibility of all parts used in ACADE. It would be great working with exported .xml and Wago Designer.
3 Comments
rhesusminus
This was added back in 2014 (AcadE 2015 - AutoCAD Electrical 2022 Help | What's New in AutoCAD Electrical 2015 | Autodesk)
Back then Autodesk had a focus on making AcadE better. That following year, the abandoned the software. The AcadE app (that you can read about in the What's new) was also something great that lived for a few months.)
Just don't expect any of your ideas to be granted.
When it comes to Smart Designer, Wago has created add-ins for other programs:
Phoenix Contact, Weidmuller.. Same thing. They have done add-ins for most other products.
Even the manufacturers ignore AutoCAD Electrical as you can see...
Just see the "What's new" for the last 10 years.. Here is a video presenting some of them:
Hi @aykutas
We have already added this under our wish list, and it is under review. We are engaging with the manufacturer.
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
rhesusminus
Please don't get your hopes up @aykutas
This means nothing.
Look at the stats: https://forums.autodesk.com/t5/autocad-electrical-ideas/i-have-an-idea/idi-p/10283447
