Wipeout for Arcs and Circles
I use the wipeout command on all footprints that sit on DIN rails, but have a hard time on components that have rounded corners. The wipeout shape usually wants to be the outer edges of the footprint. Perhaps the wipeout shape can be defined by selecting segments of the footprint.
4 Comments
Icemanau
Possibly have it so that when you click on one segment, the wipeout follows any intersecting segments as well untill it finds a gap or closes the wipeout. It should then automatically move itself to the back of the Draw Order if it closed the wipeout or ask the user which segment to bactrack to and continue on.
Regards Brad
This is a great idea!  I usually trace around rounded objects with a near to osnap.  The only problem is that Wipeout is an AutoCAD command, so we will be at the mercy of the AutoCAD developers for this.
roundy bits wipeouts???!!!!
salivating.....
Thank you for your Idea! We are forwarding your idea to our team with Autocad. They will be able to review this better.
We have added your idea to our research bucket and will be looking into it for our future releases!
Keep posting new ideas and dont forget to support others by giving kudos to their ideas.
Best Regards,
AutoCAD Electrical Team
