wd.env Variable
wd.env Variable
Can we get a separate variable for defining the path for PLC database location?
2 Comments
rhesusminus
Good idea. Never gonna happen.
royperry
Hi Jacques.
I created a case over 2 years ago regarding this option.
As you can guess, I've been told that it's impossible.
So, the only thing left for us to do is to change the path for the PLC database from the "Option" menu, under "Support file search path".
This way it will work, but you must change it locally on each computer in your network.
I don't know if you can implement it in "Deployment" installation method.
Good luck!
Roy
