If you add too many pins to a connector, you get the following message:
The software, as per too many contacts, allows you to place the extra pin connection. However the Electrical Audit and the Component Cross Reference does not report on the issue.
The only way of detecting that you have too many pins to a connector is through a Connector Plug or Connector Detail report. Can we add this reporting in either the Component Cross Reference or Electrical Audit so the issue is clearer?
