Terminal Strip Editor - Frequently used parts/accessories list
In Terminal Strip Editor my department is always adding the same parts (End brackets, Tag carriers, End plates, etc.) to our terminal strips as accessories.  It would save a lot of time if there were a button for "Frequently used parts" in the "Insert Accessory" pop-up dialog box rather than having to type in a number and then do a separate catalog lookup for each of these parts.
Thanks!
4 Comments
HavaLilFaith
Yes!!! Would save a ton of time on jobs with multiple terminal strips!
rhesusminus
Are you aware that you can add parts to a favorite list in the catalog browser?
Icemanau
I get what the OP is saying.
They want some way to click a button to insert an accessory and then either select the part from a list within TSE or go through the whole routine of calling up the catalogue to find the part.
Regards Brad
Correct Icemanau.  When I bring up TSE, I have to right-click and "Insert Accessory", then manually type a name in the "Number" field as well as do a Catalog Lookup for each part.  Just seems like there could be a Favorites button here for those parts that would let you use the Cat Browser.
Thanks for taking the time to check this out!
