Show Wire Networks With Wire Sequences Assigned
An option to hightlight the wire networks on a drawing that have a wire sequence assigned to them.
Similar to the wire highlight option in the Drawing Audit tool.
8 Comments
Also, as an option, I'd like to see the ones that DON'T have a sequence applied, that way I can quickly spot any that I might need to work on.
Great idea!
vikas.vaishnav
Thanks for your feedback. We already have this option in our enhancement list, something similar to what we had in ECS CAD. We shall review the idea and update you for same.
Thanks and Regards,
Vikas Vaishnav
AutoCAD Electrical Product Team.
vikas.vaishnav
Thanks again Randy for 1:1 feedback on this.
Wanted to understand expectations from larger set too. So a question to all others:
Q: What if we had a default wire sequence defined to all the wires in a project. Then there would be no wire without wire sequence assigned to it. Would you still want some enhancement to the wire sequencing?
Thanks and Regards,
Vikas Vaishnav
Icemanau
Yes, there does need to be some sort of improvement.
For instance, if you highlight ALL networks with a defined sequence, have the highlighting done in multiple BRIGHT colours to show the different networks rather than all the one colour.
Other enhancements I can think of...
A command line switch or button to swap between defined and undefined sequences.
Also have an ability to highlight a sequence that is automatically generated depending on wire connections rather than user defined.
Regards Brad
Just yesterday I had a discussion with field crews where being able to spot networks without an assigned sequence would have helped greatly.  Assigning a default sequence sounds dangerous.
t_chaws
Status changed to: Accepted
Status changed to: Gathering Support
