SCOOT issues when rotated, scooting multiple components relative
Sometimes i add components into a circuit, and at some point need to rotate the whole circuit by 90Degrees.
At this point AESCOOT stops working(it tries to scoot in the direction of its initial placement), i have to rotate back 90Degrees, then Scoot, and rotate back again.
The ideal situation would be to draw the circuit in the correct orientation to begin with, but this is not always possible.
It would also be good to be able select multiple, unlinked, components on parralell wires and scoot together. I currently scoot one, then align, which is good for the most part, unless i want components that are offset to move the same relative to each other.
Cheers
2 Comments
Thank you for your idea. We have added your suggestion to our review bucket.
We encourage you to post more ideas and dont forget to give kudos to other ideas that you support.
Best Regards,
AutoCAD Electrical Product Team
