Retag Components
Retag Components
Can the retag components defult to OK throughout the prompts as it used to do? Now when retagging a project, you have to select Do All > and then select OK as it defaults to Cancel. Only a slight change but it means less mouse movement as a simple Enter on the keyboard select the default button
2 Comments
automationstar
There is more than one command to do a retag, AERETAG & AEPROJUPDATE
Are you suggesting that AERETAG be broke down into 4 different commands like so:
1.Project (AERETAGPROJ)
2.Project (AERETAGPROJALL)
3.Active drawing all
4.Active drawing pick
miles.nicholson
No not at all. If you run a retag on all drawings in the project,the software defaults to Cancel rather than OK after you have selected the drawings you wish to process which means you have to actively select OK. The software does default to all drawings which means you can hit return to process all drawings.
Its the same on wire numbering as well. the software used to default to OK which meant you could hit return a couple of times and get through the dialogues. Minor irratation but they have changed for the worse rather than the better.
