I know that quite often, I'm have to show a contact from one panel in another panel's dwg while still showing the same contact in the panel dwg where it's located.
For example, a high speed trip relay with 10 contacts tripping a number of different panels.
Normally, I just place a contact, fill in the parent and pin information before doing a special explode.
However if the client then decides to change the relay in question or re-arrange the contacts to suit some scheme they have thought up, I then have to adjust both the original contact and the one shown in the second panel's dwg.
What we need is the ability to mark a block as a reference component and tie it back to the main location for that particular block. This would then allow any changes to the main block to be propagated through to the reference block.
Going with the trip relay example, it would be drawn in say panel 7 and all the contacts added to that panel for wiring out to terminals. In panels 1 to 6 there would also be a copy of these contacts. If these copies were a reference tied back to the particular contacts they are referring to, any change to a particular contact would then show on the copy.
These reference copies could also be included in the XREF system so as to allow the users to easily track the main component and the copy. Possibly with a (R) showing next to the location to denote that it's a reference copy in the main listing while the reference copy shows the XREF for the block it's tied to (contact/coil/switch or whatever).
This system would of course have to include the parent blocks like relay coils as well. I have seen quite a lot of dwgs that show a remote coil in the schematic which is also shown in the dwg of the panel where the coil is located.
It could also be used for terminals as well to allow multiple copies of terminals on different dwgs.
Regards Brad
