Multiple Sheet Feature Improvement for AutoCAD Products
In Autodesk Inventor when a user creates a new drawing they navigate to the left side and choose new drawing.  When the visualizations are created from an Autodesk Inventor drawing it uses the user created Inventor sheets to create the visualizations.
In AutoCAD sheet management is not user friendly.  Users must manually create layout tabs for each drawing sheet and update them whenever a drawing is changed in order for Vault web client users to easily print individual AutoCAD drawing sheets.
My company has several thousands of AutoCAD drawings which have multiple drawing sheets contained in a single Model tab with blank layout tabs.  Therefore, when someone accesses the Vault web client they are unable to easily print individual sheets from the AutoCAD drawing.  This issue is a huge obstacle for us, preventing the roll out the Vault web client on a large scale within our company.
Please add a feature to AutoCAD, like Inventor, where users have the option to use an improved sheet system.  As a Vault administrator, I do not have any control over how my coworkers who create new AutoCAD drawings without layout tabs, but if there was an improved sheet system it would save us all a lot of time and would make the Vault web client solution viable.
We need an integrated solution for sharing released drawings electronically and the current sheet system in AutoCAD is preventing our company from implementing the Vault web client.
2 Comments
Icemanau
AutoCAD Electrical does not work well with multiple sheets.
Electrical was designed to work totally in Model Space with no integration into the Paperspace layouts.
Luckily, the first layout works well with the title block tools but additional layouts do not.
To get full layout functionality with multiple layout sheets would require major changes to how Electrical works.
Major changes means that a lot of Electrical functions will have to be rewritten which will lead to a lot of bugs inadvertently creeping into the functions.
This is not to say that your idea does not have merit, it's just been posted in the wrong forum for it to have much in the way of support due to the way ACADE works.
You would do better to look at the plain ACAD forums
https://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/bd-p/706
https://forums.autodesk.com/t5/cad-managers/bd-p/112
Regards Brad
rhermancc
Hi Brad,  My suggestion is for AutoCAD and AutoCAD Mechanical.  I could not find a place to post ideas for either of these two applications, so I posted in the AutoCAD Electrical forum.  If there is a better place for me to post this multiple sheet feature idea, please let me know.
