Prompt for titleblock update
I think there should be an automatic prompt for a title block update after creating a new sheet.
It helps to have all the sheet and sheet numbers up-to-date when working with cross references, if you forget to update your sheet and sheet numbers after creating a new sheet it can cause an issues with the cross references later, which is why I feel a prompt would be a good idea.
1 Comment
miles.nicholson
This should certainly happen when you print a project, PDF a project, do an xref update on the project, a signal update or zip project
