Postprocessors for automation of design reports
Requires additional processing of many reports to meet the standards of the company.
Here is an example of the project:
The total number of sheets - more than 300
Scheme - 30 sheets
Drawings cabinets - 12 sheets
The remaining sheets of the project (more than 258) - Reports.
It takes a very long time to manually on standards draw such a large number of sheets of reports. Application process must be automated.
In electrical engineering projects a lot of different reports.
Reports are very important in the manufacture. They are used for the procurement of the necessary components; during assembly the product and installation of wires and cables; for programming, validation and testing ...
Automatically generated and executed by the standards of the company reports significantly reduce development time and improve the quality of projects.
3 Comments
ccad2509
its the achilles heel of acade at the moment
report generation is totally rubbish
fundamentally flawed with the rubbish report generator that's basically looks like an embedded Excel spreadsheet
if you set the system to report one per page for say cables you then have to go through the pain of editing each title block to give it a title relating to the report
200 cables means 200 pages to edit
which you then lose if you generate the reports again
its pig slow genarating forms
you cant have a proper report template with lines arcs circles company logos in
a fundamental re write from the ground up is the only solution but that wont happen
Smiley Frustrated All the top CAE electrical products have editable template forms which one doesn't you guessed it ACADE
Thank you for your idea. We have added your suggestion to our review bucket.
We encourage you to post more ideas and dont forget to give kudos to other ideas that you support.
Best Regards,
AutoCAD Electrical Product Team
