The way ACADE works, a smart block is created and inserted into a drawing. If it is a schematic drawings most symbols are inserted onto a wire.
For SL and 3L drawings, in order to be able to insert a switch or a transformer on a bus, the bus has to be a smart wire.
On our present dumb drawings (SL and 3L) we use PLINE's for our bus. Different voltages on the bus are represented with different line thicknesses. Right now ACADE doesn't support making a wire a different line thickness without turning the line weights on.
I would suggest creating PLINE WIRES so that we can simply insert blocks onto a wire that has the proper wire name and line thickness.
If PLINE WIRES were available for use we wouldn't have to modify the wire width itself and turn on line weights to see them.
Subsequently, there is a limited number of line width selections ACADE provides and with PLINE's they are infinite.
This will also give us the ability to use move component, toggle symbol, and other features that make symbol manipulation so great in ACADE.
Randee Williams
PLINES WITH DUMB SYMBOLS
SL USING SMART BLCOKS AND SMART WIRES
SL USING SMART BLCOKS AND SMART WIRES WITH LINE WEIGHTS TURNED ON (There is some overlap on the symbols and the PLINE way is cleaner)
