Hi Autodesk Team,
We have a requirement where the parent description updates need to be reflected in the corresponding child elements automatically, using an AutoCAD Electrical (ACADE) popup window.
Our parent element consists of more than 28 descriptions. We attempted to create a block using the RATING attribute, but the ACADE tool has a limitation of a maximum of 12. To overcome this, we added a miscellaneous attribute to display values in the parent block. However, during the update of the parent, not all descriptions in the child are updated due to the miscellaneous attribute added in the parent block. We need a solution where 28 or more attributes can be added in the parent block and the child needs to be updated automatically using the AutoCAD Electrical popup window.
Manual Updating each child contact distributed over the entire schematic is time-consuming for us and also leads to mismatches in the descriptions.
We have attached DWG files along with our requirements. Please check and provide a possible solution. It would be of great help to us
