Need Search option in Project when link child to parent
When I insert a relay contact and try to link it to its parent relay coil, there is no search option available in the selection window. For example, if I want to link the contact to relay number KF980, I must manually scroll through the entire list to find the correct relay. This process is very time-consuming, especially since the relays are not listed in sequential order even after Sort option check.
I am facing two main issues, as shown in the attached image:
  1. The drawing sheet numbers are not arranged in sequential order.
  2. There is no search option in the parent selection window to quickly locate and select the desired relay number, which results in unnecessary delays.Parent Child linked issue.JPG
11 Comments
alwazZWWQ8
Community Visitor
Facing same issue
mzkhanKBBK8
Community Visitor
yes i also face same issue
MAYRandhawa
Community Visitor
Facing the same issue.
wahmedF2GA5
Community Visitor
need to add this feature in Autocad electrical for quick working, also sheet sorting not working properly.
mnasirJYWGB
Community Visitor
Facing same issue
abqadeer
Community Visitor
This issued should be resolved as soon as possible to make software work smoother and reliable.
sumnoon
Community Visitor
Should be aded
mzkhanKBBK8
Community Visitor
thanks
rhesusminus
I'm glad to see such enthusiasm, but this is AutoCAD Electrical. Nothing is going to change.
Ref: https://forums.autodesk.com/t5/autocad-electrical-ideas/i-have-an-idea/idi-p/10283447
I've been working with AutoCAD Electrical for 23 years, so believe me when I say nothing is going to change.
KRajendranRD4M8
Yes, Need some search or filter by tag, location sheet..
pmccutcheon
yes, filter, sort, search options. The parts DB (catalog) has powerful lookup features.
