MULTIPLE WEBLINKS IN CATALOG DATABASE
It would be nice if we could have the option to add multiple web links in the catalog database. Instead of adding multiple web link attributes to blocks. This way the files or websites we want to open could be tied to a part number instead of having to edit an attribute for different parts.
For example.
I have two fuses in my schematic, this uses the same block.
My first fuse block is a Bussman CHCC1DU, and I want to be able to open the spec sheet, and the declaration of conformity.
My second fuse block is a Bussman CH30J1, and I want to be able to do the same thing.
If I could attached the documentation to the the catalog data, I wouldn't have to manually do this every time with every different block I have.
Then with the catalog check in the edit component dialog box the web/view button would open the seperate files instead of having to use the surf utility.
Thanks!
