Mark as normal wire number
There is a "Fix" tool.
I suggest adding a reverse tool - "Mark as normal wire number".
8 Comments
Unfix is not in the dropdown menu as you have shown, but available in the Project >Utilities, which is very handy if you have multiple wire numbers to FIX of Unfix drawing wide or Project-Wide in one sweep. I use this feature a lot.
galashkina
I'm missing the option " Active drawing (pick)"
It it is greyed out make sure your working drawing is added to the project tree.
galashkina
I would like to select several wires (not all) in the active drawing.
I believer there is no command to Unfix wire number by single pick. I will post if I find one. But there is other way of doing this. First unfix  (set all wire numbers to normal) drawing wide (active drawing) and then use fix command from the dropdown menu to change the wire numbers to fixed by picking one by one. Not ideal but does the job till the solution is found.
I don't think there is an unfix command by single pick.
https://forums.autodesk.com/t5/autocad-electrical-ideas/unfixing-wire-numbers/idi-p/8129703
testsubject
I thought this sounded familiar...
s.wile
I don't use this selection Fix tool often. But I totally expected it to toggle a fixed wire to normal. Not sure that a new tool is needed. Just enhance this one to toggle on single selection picks maybe?
