Make the source file path for blocks in tool palettes relative instead of absolute
Hi everyone,
Would it be possible to make the source file path of blocks in tool palettes relative instead of absolute?
Indeed, because the source file path is absolute, when the tool palettes and their source files are stored on a drive such as OneDrive (to name just one), the tools no longer work when importing the palettes onto a different workstation than the one they were originally created on.
The issue comes from the fact that the source file path is absolute.
For example, on workstation A, the tool palettes are created using DWG files stored on OneDrive. The source file path is, for instance:
C:\Users\WORKSTATION_A\OneDrive\CAD\MY_TOOL_PALETTES\TREES.dwg
On workstation B, when the tool palettes are imported from the drive, the source file path becomes:
C:\Users\WORKSTATION_B\OneDrive\CAD\MY_TOOL_PALETTES\TREES.dwg
As a result, the path is not the same, since the username changes, which means AutoCAD can’t locate the source file for the block.
Even if a new path is added in AutoCAD's options—either in the support file search paths and/or in the tool palette file locations—it doesn’t work.
If the path were relative, for example:
.\TREES.dwg,
then the tools should always work, regardless of which workstation the tool palettes are imported on.
[Translated with ChatGPT.]
____________________________________________________________________________________________
Salut à tous,
Serait-il possible de faire en sorte que le chemin du fichier source des blocs, ans les palettes d’outils, soit en relatif et non en absolu.
En effet, du fait que le chemin du fichier source soit en absolu, lorsque les palettes d’outils, ainsi que les fichiers sources, sont sur un drive, tel que One Drive, pour ne citer que lui, lorsqu’on importe les palettes sur un poste, autre que celui, à partir duquel elles ont été crées, sur un autre poste, les outils ne fonctionnent pas.
Le problème vient du fait que le chemin des fichiers source est en absolu.
Par exemple, sur le poste A, on crée les palettes d’outils, depuis les fichiers dwg qui sont stockés sur One Drive. Le chemin du fichier source est, par exemple, celui-ci :
C:\Users\POSTE_A\OneDrive\CAO-DAO\MES_PALETTES_OUTILS\ARBRES.dwg.
Sur le poste B, lorsque ‘on importe les palettes d’outils, depuis le drive, le chemin du fichier source, est celui-ci :
C:\Users\POSTE_B\OneDrive\CAO-DAO\MES_PALETTES_OUTILS\ARBRES.dwg.
Par conséquent, le chemin n’est pas le même du fait que le nom de l’utilisateur, change, ce qui fait qu’AutoCAD, ne peut pas aller chercher le bloc, dans le fichier source.
Même si dans les options d’AutoCAD, on ajoute un nouveau chemin, dans les chemins de recherche de fichiers de support de travail et/ou dans l’emplacement du dossier des fichiers de palettes d’outils, ça ne fonctionne pas.
Si le chemin était relatif, par exemple :
.\ARBRES.dwg
les outils devraient toujours fonctionner, Quel que soit le poste sur lequel, on importe les palettes d’outils.
2 Comments
rhesusminus
This is the AutoCAD Electrical Ideas forums, not plain AutoCAD, and it's not monitored much by anyone.
_Steven_
There is no AutoCAD Ideas forum.
Also, as far as I know, my question applies to all versions of AutoCAD.
