KKS Numbering - Utilizing the %P Value
Can the %P value be an option to display in the Drawing List Display Configuration?
Can the %P value have a [Drawing] and [Project] selection in the Drawing Properties as shown?
The KKS standard is predominently used in the power industry especially in Germany, Denmark etc. We can then use the %P value as a higher level to the standard installation and location.
Cheers
5 Comments
t_chaws
Thank you for your idea. We have noted your suggestion and will be considering it for our future releases.
We encourage you to post more ideas and dont forget to give kudos to other ideas that you support.
Best Regards,
AutoCAD Electrical Product Team
samuli-7DQ7E
Would be nice if the Drawing List Display Configuration would load automatically. Now I need to run it every time after opening a project.
miles.nicholson
If you are having to change the drawing list display on a regular basis, I'd suggest trying using a different pc user profile. The drawing list display is not lost.
samuli-7DQ7E
My issue is to maintain the current settings. I must re-apply the Drawing List Display Configuration every time because ACAD doesn't remember it. The Configuration window remains OK, but the Project Manager display doesn't update before I open and apply the Current Display Order via Configuration window.
miles.nicholson
Yes, this sounds like corruption to your profile as you shouldn't have to do this. Log on to the pc as a different user and then check whether the same occurs under a different profile.
