When we create a project, we should be able to create subfolders for each panel, With all of the intelligence tied together, but each panel being independent. If I have 5 panels in a project, each panel should be able to have identical wire numbers and component numbers. The Project should be able to differentiate the panels apart. I should be able to have a "24vdc" wire number in each panel without Autocad thinking they are the same wire. The same goes for components. I should be able to have a "CR1" In each panel, without autocad thinking they are the same. I should also be able to put a contact from panel 1 CR1 into panel 2 and autocad links them properly.
I know I can use subsections and location to label things, but it is just a work around and does not really tie everything together. Each subpanel in the project should have a "Panel" designation so Autocad knows that they are separate panels, and act accordingly.
The way things are now, If I need to wire for one panel to another panels PLC, I have to do it manually, and they are not linked.
