Installation and locations code needs a description
Normally we use short codes code for INstallation and Location.
When there are a lot of codes, it's hard to remember what code is what.
WE can havea project with 50 junction boxes, that have a location of +JB01 to +JB50.
If we had a place to put a description for the location, it would be easier to pick the correct location when picking from the dialog boxes in AcadE.
Also, if we could include this description on location boxes it would be nice.
5 Comments
ccad2509
you forgot to mention the competion already has it Smiley Wink
t_chaws
Thank you for your suggestion. We have included your idea in our research bucket and will be looking into it for our future releases.
Keep on posting new ideas!
Best Regards,
AutoCAD Electrical Team
miles.nicholson
In addition this should also be extended to the Project Code which can be used as an even higher level than the Installation. The KKS standard utilities this as "Group", "Function" & "Location". The Project Code should also have the option of [Drawing] & [Project] selection buttons for picking codes that have been defined elsewhere within the project and within a DEFAULT.proj file
rhesusminus
You should consider having a look at the competing software "screenshotted" above Miles 😉
