Normally you insert a terminal strip with the Terminal Strip Editor and you can designate which wires are Internal and External. The wire number annotation inserts as designated and all is good in the world. Later however, someone makes an edit to the schematic that they know will affect the wire numbers of the terminal strip. Rather than rebuild the strip via the Terminal Strip Editor, they take what they might consider to be a more expedient approach by using the Wire Annotation utility on the Panel menu tab. However, if one uses this utility to annotate a terminal strip, the Internal and External assignments change and wires could move from one side to the other. Please enhance the Wire Annotation utility to refresh the terminal strip wire number annotations but retain the Internal and External designations, unless they were intentionally changed by the operator, via the Schematic tab>Edit Components panel>Terminal: Mark Internal or External Connections.
