The duplicated component TAG check works well except for it allows you to have a terminal strip tag = to another type of component tag.
I understand that you can have multiple terminals in a terminal strip and hence why it doesn’t and shouldn’t check for duplicated terminals within a terminal strip. However, the duplicated component tag check should check for a terminal strip having the same tag as another type of component (not a terminal).
This is a loophole in the current duplicated component TAG check that needs to be resolved.
