BULK EDITOR FOR SIGNAL CODES
Would be nice to have a bulk editor for Signal Codes. Suppose you want to change OP1_24V, OP1_0V, OP1_GND etc to OP2_xxx.
Yes you can use the export/import from excel currently
Would be an extension of the Find/Edit/Replace Component Data command.
Currently this command doesn't support SIGCODE
1 Comment
pmccutcheon
Edit: I often do this when cloning or copying a page or circuit or cabinet. Suppose I drafted operator station OP1, and clone it to OP2. Then I need to update all the SIGCODEs on the clone
Can also use the Autocad Vanilla Find command.
I just found it a little odd the ACE Find/Edit/Replace doesn't support SIGCODE or DESC
