At my previous employer, my emphasis was mechanical design with Autodesk Inventor. I was pleased with the ease of workflow from beginning of project to end. When I changed to electrical CAD work months ago, I got my feet wet with AutoCAD Electrical heavily (no more Inventor). AutoCAD Electrical (2015) is a great tool, and has helped us and our customers tremendously. And yes, there is always room for improvement. ACADE just seems more clunky than Inventor overall. Admittedly, I'm still green when it comes to ACADE. A couple of examples:
1I (Inventor): Update a model with the parameter needed, then open the idw. The dimension updates automatically.
1E (Electrical): Stretch a line & retag the extension line (if you did not grab certain entities). It does not always play nice.
2I: Title block updates are universal, and happen right after the modification has occured.
2E: Go to title block update function and select exactly what fields to update and others not to update.
3I: File types, ipt (model), asm (assembly), and idw (drawing).
3E: File type dwg. Perhaps the schematic, panel layouts, and BOMs would benefit greater from attributes (aka Inventor parameters) passing. This one is more of a stretch.
Like I stated, I really do like the Electrical product, and I remember thinking the same between "Inventor" circa 2001 versus 2009. Seems like Electrical is on the path of developing into an easier product to use.
Ryan Gerstner
CAD Operator
The Industrial Controls Company
