Show only
Search instead for
Submitted byAnonymouson10-02-201509:10 AM
Status:
Gathering Support
Add Draw Order Command to Panel Tab
I think it would save time to add the Draw Order command to the Panel Tab of the Ribbon to save users from having to switch to the Tabs when working on their panel layouts and having to place components on the DIN rail
Great idea! I always add Send to Back and Bring to Front myself using the CUI Editor, but it would be nice it they were already there. I also add AutoCAD Move and Rotate, AE Stretch PLC (can stretch any block i.e. DIN rail, Wire Duct), and Move/Show Attribute, Rotate Attribute, Change Attribute Size.
I think this would work equally well in the marking menu. I actually use the ribbon very little, I rely mostly on LISP macros and the marking menu. (I actually have an alias defined for DRAWORDER, but only because ACADE didn't already have an easy way to access it.)
