AutoCAD Electrical Forum
Zoom Issue/Mystery Object?
4 REPLIES 4
zsobieXK43E
175 Views, 4 Replies
I am having difficulties with my Zoom and I believe I have identified the issue, but not sure how to correct it.  All of my objects are within my Title Block, but when I do a Ctrl+A it shows a cluster of blue grips outside of title block at the point where my zoom stops.  They do not show up when I draw a box around them, only when I use Ctrl+A.  I'm not sure what they are or how they got in my drawings.  Any advice would be appreciated.
Labels (1)
  • zoom
4 REPLIES 4
rhesusminus
in reply to: zsobieXK43E
It can be anything. Impossible to tell without actually seeing the drawing. Try to purge the drawing by removing "empty texts". Or attach the drawing here, and someone will find it.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
zsobieXK43E
in reply to: rhesusminus
I have attached the DWG.
Hello @zsobieXK43E
Seems like you have some leftover floating dimensions on Layer AREA1 and AREA2
These layers were turned off, you will see the geometry once you turn the layers back on.
You might also like the PURGE command, This helps to remove all the unused objects including layers and optimize your drawing.
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-5150F6AD-3FEC-4BA0-8905-5154ABBB6E9A
Arshdeep Singh, C.Tech, CMSE®
Electrical Designer & Programmer
LinkedIn
www.blackcontrols.com
Please mark as "Accept Solution" if this resolved your issue. It might help someone else with the same question. Likes are welcome!
That worked!  Thank you
