I would like to generate tags for my components based on the sheet number and the x-y coordinate that the parent is in. Is there a way to do this?
Hi ezbz14,
First set up the X-Y grid and place it on you drawing.
(to set it to x-y, change it the format referencing in the project settings)
(to place use the "X-Y Grid Setup" command hidden in the dropdown for Insert Ladder.)
Next set your component tag to %S%N.
%S is the sheet number
%N is the reference number (in this case the X-Y value)
I hope this helps,
James
Glad I Could help.
