Hi all,
I just put wire number for cable.
but for this project the process very slow, each label need about 2min, for other project dun have this issue.
may i know have any setting about this ,
attached Video for your reference,
Solved by rhesusminus. Go to Solution.
Are there any special characters in the project/drawing file names or path?
How about the project descriptions?
If you move this drawing into a working project, is it faster then?
if i haven active project i try to change label,
dun have this proble,
i juest do it first because i also dun know where have issue,
thank you .
I'm not sure if you found a solution to your problem.
