Wire secuense according a panel layout
marcolrsm
marcolrsm
hello everyone hope you are doing well.
I have the next issue.
I have finished all de circuits of my project and now i want to make my wiring diagrams to send them to my customer but i need to do the wire secuense. I was wondering if there is a way to do the wire secuence according the layout of my cabinet, for example:
I have this circuit
and the layout of my cabinet is like this
i want to know if there is a way to do the secuence according the layout (right to the left - bottom to top)
The (number 1) is the Fuse (UP) that goes to the (number 2) terminal 39 of the terminal block (TC) then it goes to (number 3) terminal 5 of the terminal block (TF) and the next (number 4) goes to the terminal 29 of the terminal block (TT).
In this case i did it manully because i was trying to do it with the configurations of the project properties but it seems that it doesn´t repect the equipment disposition or maybe there is nothing that saids to autocad that has to follow that secuense
james.mcmillanNYR6A
If it helps, I think the wire sequence sort order is based on the position on the schematic drawing, not position in panel.
rhesusminus
As James said, you can't optimize the connection sequence based on the placement of the devices in the panel using AutoCAD Electrical.
Eplan however, can of course do this.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
ccad2509
Trond
Sstop taunting these poor souls with functionality that other products have as standard
as we know
sticking a load of lisp routines on top of a 2d drafting tool is never going to give you any way of routing as that’s a 3d function
let them live in the Autodesk world where the delusional believe that acade is actual a competent electrical design tool
remember the chant
“ACADE is the only electrical design product and it’s the best”
All other electrical design products are fake news !!!!!!
