Dear Sir
I have draw the wire when I try to insert wire numbers it show Question mark (?)
kindly send the solution on the same.
Thanks & Regards
Atul Vishwakarma
Your drawing numbers are set up to use line reference numbers for wire number:
However... There are no Line Reference numbers to inherit the number from. Insert a ladder:
Now, renumber the wire numbers:
Hey guys,
Please see if anyone here can help me to solve this situation:
My wires ID are with "?" and I don't know why...
Have you ever seem this problem and how to solve it?
Doug
Jim you nail it! Thanks, but I am still curious about how smart is the AutoCAD Electrical in regards of wiring identification. Please see one more issue below:
The wires: W400-1 and its sequence is perfect identified.
The wires from P407 should not be numbered with the number 1 because it is other segment/ function. It should be W400-2 for the wire W400-1F and W400-3 for the W400-1G.
Is there anyway to have this config working automatically?
Thanks Jim,
Doug
