I am wondering if there is an option to place wire labels (without a leader) through a function such as multiple block insert?
Not exactly sure what you are asking for. You can already insert multiple Wire Labels by selecting several wires at a time.
I understand now. I always use leaders/automatic so had not noticed that was not available with no leader. I do not know what to do here. Sorry.
I think you can use a cheat here.
I have some scripts that hide layers as a last action, i can add this to it; however, it doesn't stop the displacement of the wire number, does changing arrow and gap to 0 work? I will try it time permitting and revert.
your example is of wire gauge, maybe it will also work for wire numbers, I know the format is near the same.
