Hello, guys, I'm still new to AutoCAD Electrical, every time i insert a component, i get the question marks on components tags, how do I solve this problem?
Thank you.
The topic title has been edited to improve findability by @alina.balkanskaia. Original: Component tags
Solved by rhesusminus. Go to Solution.
Your tag is set up to use something (the sheet number) in the tags maybe?
And, you haven't filled the sheet number into the page properties??
